Selling the following items to clear out garage:
item: A complete set of Bilstein Shocks + Eibach lowered/stiffer springs to suit R33 GTS-t Series 1 or 2. Used for the last 8 months with just normal street/hills use for which they are absolutely perfect. Excellent spring rate which gives fantastic handling and a significant reduction in body roll whilst being perfectly comfortable for street use.
Price: $700 Now SOLD
Pics soon!
Item: Pair of R33 Front Rotors in excellent condition heaps of meat left as shown in pic with only a little even wear since new. Measured thickness which is at 29.1 and 29.2mm so not even half worn. Fits R33 Caliper equiped vehicles
Price: $80 pair Now $60 pair
Item: Pair of Jap 12mm thick bolt on wheel spacers complete with studs and bolts, that bolt onto 4x114.3 hubs and allow you to fit 4x100 wheels. Was used on my S13 to space my wheels 12mm as I had 4stud wheels that had both 4x114.3 & 4x100 stud patterns so was the perfect solution. Can also be used as a 12mm spacer for either stud pattern if you had longer wheel studs.
Price: $100 $80 pair
Boost Controller - electronically activated boost controller valve allowing you to run stock boost and then at the flick of a switch run the boost level you set on the valve. Needs a switch as the one I used for this is still mounted on my console and too difficult too remove again :thumbsup:
Price: $60 $35
Z32 AFM Plugs + ~30cm of loom ready to splice or wire into your loom to run Z32 AFM. Come complete with instructions on wiring into SR, CA & RB Powered Vehicles
Price - $30 Delivered or $20 pickup
Pair of R33 Front Seats in excellent condition. The drivers seat has a small tear in bolster nothing major. This is the comfy plush velour type model with the adjustable side bolster wings for more support through corners etc.
Price - $150
R33 Internal Heater Fan assembly includes fan itself along with the air intake & recirculation electrics etc in excellent condition.All is as shown in pic perfect if your fans packed it in so it no longer blows air in your car. In excellent condition little dusty just give it a quick wipe before fitting.
Price - $30
R33 Stock Actuator in excellent condition to suit R32/R33 turbos
Price - $25 $20
Aftermarket Swaybars
S14 Front 27mm hollow swaybar, same thickness as whiteline HD but a hell of a lot lighter, painted black complete with D bushes, saddles and end links. Hollow bars are generally how the japs make their aftermarket swaybars as they perform the same as solid but save weight which also increases handling. Unsure if it fits S13/S15 Price - $100ono
Stock Sway Bars - $25 each
R33 Front Stock complete with D bushes and saddles but no endlinks
R33 Rear Stock complete with D bushes but no saddles or endlinks
S13 Rear Stock complete with D bushes but no saddles or endlinks
Freebies
Pair R33 Front Castor Rod Chassis Mounts
Pair S13 Rear 4 Stud Hubs
Adelaide but will post some items at your expense
Contact:
SMS 0404998591 or PM prefer SMS
Edited by nigelswazi
Do you also have a pic of how low the car sat with the Bilstien / eibachs?
I have one on my computer at work will post one when I get there.
CAn you give a vernier measurement on the thickness of the rotors?
As soon as I find my vernier but they are a old school set not digital will see if I can borrow or take to ABS or somewhere to get measured. Heaps of meat tho
got a pic of the front seats?
Cheers
Jo
Hi Jo will get a pic for you asap
Is the suspension height or damper adjustable?
Suspension is not height adjustable but you can always get the shocks modded to runs circlip height adjustability if required. Shocks don't really need adjustment as they give a excellent ride quality from both handling and comfort perspective these are basically the same as the SK group buy setup for a fraction of cost.
Rotors are 29.1 and 29.2mm thick using my vernier calipers so they are not even half worn yet. Minimum legal thickness is 28mm
FINAL PRICE DROP CRAZY CHEAP PRICES
Post Updated
R33 Rotors Backup for Sale
Coilpack Cover SOLD
Pioneer Stereo Package Now SOLD
Special Weekend Prices!
do you have the little black box actuactor with the white arm on from the heater assembly it opens the bottom flap for the heaters ?
cheers dean
cheers dean
Certainly does has the box complete with the white arm still assembled
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
