hi ,
I am frensh so sorry for my poor english ... :huh:
I have a skyline ECR33 GTS T since 3 years , I do drift with this car since this time ...
I search sometimes tips for my nissan , and your forum is very rich in informations :dry:
so From the time that I travel around your forum, I decided to introduce myself today ...
In france , skylines are very very rare , and it is not very easy to found parts or tips when she don't want run ...
I am installing a power FC , so I going to search informations for ingnition and injaction timing :D
just one or two photos :
see you soon :dry:
https://www.sau.com.au/forums/topic/213745-william-new-from-france/
thanks for your welcome :banana:
In france, it is very hard to find RUNWAY(circuit) who accept drift ... frensh people are afraid to see cars in drift ... And say that it destroys the runwayBut we continue to believe through our association (http://www.forum-drift.fr/) , we try since 5 years now , and always as hard ...
There was a championship last year , I finish 4nd ... I don't know if I do the championship this year ...too much money and 0 sponsors
I think in Australia drift is bigger when I see video on MOTOR TV :P ...
yes , I make all my skyline , I buy in japan there 3 years , it was stock , Since this time I do the modification when I can ... I just rebuild my motor this winter , this motor is very strong , it was 85000 kms and all was new :cool:
NISSAN SKYLINE GTS_T 1995
MOTEUR : RB25DET
- TURBO HKS GT25/30
- exhaust system KAZAMA
- intake manifold TYPE GREDDY
- INTERCOOLER
- BLOW OFF SSQV HKS
- FUEL REGULATOR
- INTAKE APEXI
- FLYWHEEL EXEDY + KIT CLUTCH MFA 6 PTS
- WATERSPRAY CUSCO
- OIL CATCH TANK
- COMETIC HEAD GASKET 1.2MM + ARP
GESTION / CONTROLE
- E.C.U POWER FC
- BOOST CONTROLLER GREDDY PROFEC01
- MANOS STEWART WARNER
CHASSIS
- JANTES 8X18 AV + 9X18 AR
- SPACER ELARGISSEUR DE VOIE + 15MM
- COIL OVER D2 D2 RACING
- BRAKE D2 RACING 352MM ETRIERS 8 PISTONS
- HAND BRAKE HYDRO D2 RACING
- CAMBER FRONT + REAR
- BAR ANTI-RAPPRO FRONT + REAR X3
- ROLLCAGE 9 PTS CUSCO SAFETY 21
- TIE ROD KAZAMA
- HICAS LOCK
- LSD 2 WAYS CUSCO TYPE RS
INTERIEUR
- SEAT COBRA
- HARNESS 4 PTS COBRA
- SHORT SHIFT
FOR 420 REAL PS :spank:
ETC...
Edited by williamECR33
tie a ribbon around the base of your cock with the ring on it. then tell her if she can get her mouth on as far as the ribbon she can have the ring
Hi Willy..
Its looking good mate, welcome to the forum its great to have people from other parts of the world.
Do you drive the beast in the streets of Paris or Marseille at all? If so what are peoples reaction when seeing a different car?
hi :D
no drift in streets of paris or marseille :D , I live in a little country in center :geek: .
The people don't see my car in road because skyline can't drive in france :( , we can't Approved it... :ermm: , and Majority cops don't like sport cars ... :blink:
only the GTR(r35) will come in middle 2008 ...
how is drift and skylines in AUSTRALIA ?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
