Make:Nissan
Model:Skyline GTR
Milage: 87,XXX
Transmission: 5 Speed
Colour: Black
Complied? YES
RWC supplied? NA
Currently registered? YES
Price: 18,000 ONO
Contact: 0402640422
Comments / Modifications:
G4 Coilover 4000km old
3 1/2" exhaust
Single plate HD clutch
Alpine MP3 system
Alarm/windows lifters + immoboliser
HKS SSQV blow off valve
K&N air filter
Mines ECU
Autometer boost, water and oil gauges
JJR adjustable cam gears
JJR pipings
I bought this car in Oct 2006 when it had 76,XXX km on it and i only used it for weekend driving now it has about 87,XXX so only did about 11,000k in about 16 months
cheers
Huy
Images:
Edited by nuganen
https://www.sau.com.au/forums/topic/214143-r32-gtr/
  • 3 weeks later...
