Hey
I wanna get my R32 GTR Serviced and was wondering whats the best oils I need and how much I would need of them.
Gear Box - Redline Oil - What one? And how much of it do I need?
Diff Oil - What one? And how much of it do I need?
Engine Oil - mobil 1 synthetic - What one? And how much of it do I need?
And any other oils anyone recomends to change.
If there is a difference on different oils for where you are located, for driving coditions, Im located in Qld
Thanks
M3M3NT:burnout:
https://www.sau.com.au/forums/topic/21422-r32-gtr-service-oils/
Engine oil - Mobil Syn 1 - you need 4.5ltrs
G'box oil - Redline lightweight shockproof - 3.6ltrs
Diff oil - Shell Fully Syntheic diff oil (for LSD and non LSD)- 2 litres.
The last one is what im using in my diff, It quitend it down a fair bit (and I regained my double pegger skidz ability)... But you will probably need 2x as much because you have a diff at the front. Since you are servicing a GTR dont be a cheap arse, the car will love you for every bit of lube. Try and get who ever is doing it to grease the uni joints in both tailshafts too, coz I could bet my left nut that the japs wouldn't have botherd.
Also, im not to sure on how the Attesa system works, but I would get the oil dropped out of the transfer case and replace that too. If you drain your brakes and put a Dot 5 fluid in there I makes a big improvement (unless you have already done this...)
Cheers
Sumo
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
