Make: Mitsubishi
Model: 3000GT (Australian delivered version)
Milage: 102xxx
Transmission: 5 speed manual
Colour: Triple core pearl white
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: $36,000 or trade for a Honda S2000
Contact: 0430 560 156 or PM me
Comments / Modifications: ZOOM mag feature car (issue 119)....see below.....
Images: see below.....
This undoubtedly has to be one of the finest 3000GTs in Australia. The fact that this car is a genuine Australian delivered 3000GT (not a GTO) only elevates its uniqueness. Light-years from the standard coupe, this GT has been tastefully modified with a premium list of components.
Under the ownership of a meticulous and fastidious owner, the car has always been garaged and serviced every 5000km with quality products. This car was never bought with racing/hooning in mind - owned and modified by a mature owner the car has only been taken out on the occasional weekend for motor events. I.e. it was never used as a race/track car.
As revealed by the pictures below, the car is vastly overloaded with numerous electronics and audio/video gear. This often misleads individuals to believing it as an all-show - no-go car. Nevertheless, as misleading as it may be, the cosmetics conceal a heavily modified 3.0L V6 twin-cam powerhouse. Coupled with two aftermarket turbochargers, standalone engine management system, and an inoculation of nitrous oxide, the car utilises its all wheel drive system to deliver neck-twisting torque and power levels of 780Nm and 400BHP.
All in all, this car has proven to be a showstopper as well as one that can stand up to its expectations on the street. In putting together a car with all the correct show-and-shine components and performance modifications, this truly does combine extremes of both worlds. It's unique in many ways, and has to be seen to be appreciated.
For more details refer to the feature article in the November 07 edition of ZOOM magazine (issue 119).
post-49931-1207791734_thumb.jpgpost-49931-1207791741_thumb.jpgpost-49931-1207791749_thumb.jpg
QUICK FACTS
• Power output at the wheels – 307.8kW / 410.4BHP (at all four wheels)
• Estimated power output at the flywheel – 500-550BHP
• Estimated Torque – 780Nm @ 5500RPM
• Operational boost pressure – Low boost (10PSI), High boost (16PSI)
• Nitrous Oxide shot - 75 shot fogger ported
post-49931-1207791755_thumb.jpgpost-49931-1207791763_thumb.jpgpost-49931-1207791771_thumb.jpg
PERFORMANCE MODIFICATIONS
• PWR mammoth 5" thick intercooler and custom stainless steel piping
• Blood red brake callipers with Bendix Ultimate racing pads
• Turbosmart Megasonic dual-port Blow Off Valve
• High Energy Stealth Vacuum Hosing
• Twin Drift urethane hi-flow POD breathers
• Custom stainless steel intake pluming (by passes MAS unit)
• Re-positioned aftermarket oil cooler
• Mr Turbo stainless steel downpipe and high-flow catalytic converter
• Twin Mr Turbo high-flow 3.5 inch cannons
• Mr Turbo 3.5" stainless steel exhaust running straight through cat-back to turbo ends
• EMS aftermarket stand alone engine management system with LCD touch pad hand controller
• Pioneer Vehicle Dynamics Module (data logging/analysing & GPS system)
• Greddy high flowed, ball bearing turbochargers
• NOS Fogger ported 75 shot nitrous oxide system with polished aqua blue 10lb bottle
• Walbro 255 high flow performance fuel pump
• M-Spec adjustable rising-rate fuel pressure regulator
• Fuel pump relay modification & direct hot-wiring to EMS computer
• Getrag 5 speed manual transmission with aftermarket carbon/ceramic 6 puck dual friction heavy duty street clutch
• Apexi AVC-R (Actuator Valve Controller) boost controller
• Apexi SFACII air-fuel controller
• Apexi Stick turbo timer
• M-Spec lightweight aluminium crankcase catch tank and radiator fluid overflow catch tank with mini POD breather
• High density heavy duty 660CCA sealed lead acid battery
• Bosch 8.5mm super conductor HT ignition wires
• NGK platinum tipped racing plugs
• 19" two piece Koya wheels (semi-solid forged aluminium alloy with inox lip)
• 245/45/ZR19 low profile Falken rubber (94Y rating)
• All Shell fully synthetic oils & lubricants
• Newly replaced Mitsubishi OEM engine mounts
• Newly replaced Mitsubishi OEM clutch master and slave cylinders
• Street Glow scanner hot-wired to alarm module (LED's repositioned to defroster vents)
post-49931-1207791777_thumb.jpgpost-49931-1207791783_thumb.jpgpost-49931-1207791790_thumb.jpg
INTERNAL COSMETICS
• Custom 320km/h Speedometer
• Custom 10,000RPM tachometer
• Momo shift knob
• Type-R aluminium racing pedals
• Momo lightweight boss kit with Momo dual-fighter steering wheel wired to activate NOS and stage 2 boost
• Apexi AVC-R boost controller
• Drift Neo series boost gauge
• Drift Neo series oil temperature gauge
• Drift Neo series oil pressure gauge
• Drift Neo series water temperature gauge
• Greddy Grex series A-pillar double pod adaptor
• Centre gauges removed and replaced with a/m units
• AeroPro digital dual-temperature stick (NOS bottle temperature)
• JBL GTO2000 400W amplifier with cooler fan modification
• Response Precision 2 farad capacitors
• Sony Playstation with dual force feedback hand controllers
• 1x Sony Xplod 15" 1000W compression subwoofer
• 2x Sony Xplod 12" 1200W compression subwoofers
• Pioneer slim line fully automatic touch screen DVD player
• Pioneer 6 CD stacker module
• Pioneer tape/tuner head unit with CD/MD stacker control
• Sony 5" secondary informative monitor
• Pioneer 6" 3 way splits
• Pioneer 2" tweeters
• Pioneer gold plated cross over units
• Panasonic 9x6" rear 3 way tyrants
• Stinger monster cables and platinum blocks
• Stinger gold plated battery terminals
• Fusion 80A gold plated master fuse
• Rockford Fosquare 40A gold plated secondary fuse
• ConCord monster RCA cables with gold plated end fittings
• Modified center console with soft-touch push buttons
• Brain-Vibrations boot installation with carbon fibre finish
post-49931-1207791795_thumb.jpgpost-49931-1207791801_thumb.jpgpost-49931-1207791807_thumb.jpg
EXTERNAL COSMETICS
• Custom light weight adonised aluminium fully adjustible dual blade GT wing
• Unique triple core pearl white paint
• Narva Xenon plasma ultra white/blue lights all around
• Custom matt-black front skirt/lip (lower intercooler piping protection)
• Detailed engine bay with colour coordinated components
• Resprayed intake plennum (mystic silver)
• Aluminium mesh grilles – oil cooler and intercooler protection
• Street Glow under car neon kit
• Street Glow front mount intercooler illumination neon
• Street Glow IR remote control module for under car neons
• Desert Storm window tint
• Clear front indicators (euro version)
https://www.sau.com.au/forums/topic/214273-400awhp-australian-delivered-3000gt/
Mate, thats a pretty tough car...
gl with the sale
Thanks mate...its a great little car. But I've hardly got time nowadays to drive it. Majority of the time it just sits in the garage. So I have to part away with it :-(
  • 1 month later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
