1994 Nissan Skyline ECR33 GTS-T - 130000km
Gold Coast
Regretful sale, I have never had any mechanical problems with this car. The condition of the car reflects how well it has been looked after.
16K ONO
Will consider SWAP for late model Crew Cab ute
PERFORMANCE MOD'S
~GREDDY Intercooler
~GREDDY E-Manage Computer
~GREDDY Boost Controller
~BLITZ Blow Off Valve
~WALBRO 600hp Fuel Pump
~Full 3" Exhaust
~EXEDY Sports Organic Clutch
~Shortened Shifter
~APEXI Air Filter
~Front Strut Brace
~TEIN Adjustable Coil Overs
All performance work done by Millenium Motorsports
OTHER EXTRAS
~Dark Tint
~Body Kit with Stealth Spoiler
~17" ENKEI Rims
~Custom Leather Trim
~MOMO Steering Wheel
~NISMO Leather Gear Knob
~NISMO Clear Side Indicators
~Leather Racing Seats - mod plated
~TIMEX Gauges (Oil temp, Boost)
~GREDDY Turbo Timer
~White Instrument Cluster (with red lighting)
~$1300 Security System. More details on request.
~PIONEER MP3 Player
~PIONEER 6" Splits in doors
~6"x9" Rears
~2 x ALPINE Type S 12" Subs
~ALPINE Amplifier
Rego until June 08
Call or msg Aaron on 0431 420 255
Edited by AiR
https://www.sau.com.au/forums/topic/214483-94-r33-gts-t-skyline-16000-ono/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
