Item:HP IPAQ HX2100
- 312MHZ processor
- 128MB onboard memory
- 64K Colour screen
- Windows Mobile 5.0 2003 SE
- Dual CF and SD slots (rare for a PDA to have both)
- Bluetooth
- Infrared port
Globalsat CF GPS card (SIRFSTAR III chipset)
Cold satellite aquisition is around 20 seconds, hot acquisition is virtually instant. Usually holds a lock on between 5 and 7 satellites at all times.
Toshiba 256 MB SD memory card
In-car PDA cradle with built in speaker and charger
Age: Approx 1.5yrs
Condition:Everything is in perfect working order and immaculate condition. The PDA still has the factory screen protector on it (so the scratches in the pics are the screen protector not the screen!!!!)
Price:$300
Contact: Via PM
Comments:PDA comes with PC USB docking cradle, wall charger (use with cradle), and all factory packaging and documentation.
I bought this all separately and set it up as a GPS navigation unit. And it works perfectly as a GPS system.
The cradle has a built in amplifier and speaker for amplifying voice navigation instructions and a charger for charging the PDA. The dual slots make it ideal for GPS, the CF slot is used for the GPS card and the SD slot is used for a memory card that holds the GPS software and maps.
Currently it has TomTom Mobile 6 installed with Australian maps (full turn by turn voice directions and auto route re-calculation). It will come with this pre-installed on the SD card and ready to go. You can use other mapping programs if you wish.
Its effectively a TomTom GPS unit but with the bonus of full PDA functionality (email and internet via bluetooth, organiser, word processor,etc.)
I'm only selling due to my parents buying a dedicated GPS unit for the family to share.
The only thing to note is I have lost the CD that had Microsoft Activsync on it (this program is installed on your PC/Laptop so it recognises the docking cradle). However this is freely downloadable from the Microsoft website, and I’ll probably even put a copy of it on a CD with the Tomtom software anyway.
Pickup from the Northside of Brisbane, or postage can be arranged will probably be expensive due to the large boxes.
Epiphone Les Paul Studio, LTD EDN
Blue with pearl strike plate and truss rod cover.
Solid Mahogany body and neck,
Near new Ernie Ball strings
They aren't made any more as it was a limited edition, They sold new for $800, still has all factory packaging etc
Excellent Condition $600, pickup only.
Tanglewood TW28STR-CE-NA
Acoustic/electric with cutaway
Solid American spruce top, Mahogany neck, Rosewood back and sides,
Ernie Ball Slinkee strings, plus spare set included,
Comes with old hard case and stand.
Excellent Condition $450, pickup only.
Marshall MG15 MS-11 Micro Stack (same warm up amp used by Slash.)
2 separate cabinets each with 10” speaker
Stands approx 1m tall!!!
15W head, with spring reverb, overdrive, EQ, Marshall FDD,
Awesome sound and loud for a “small” amp.
As new condition, still with all original packaging.
$450 pickup only.
Contact via PM thanks.
Edited by Ashman
  • 3 weeks later...
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
