did you get this from
K.S & Sons in Myaree??
looks like the one I was checking out..not sure tho cause they got heaps..haha
was looking at this one and the red one they got for sale..but red aint my colour..so waitin for there new stock :P
Edited by viet_boi
Hey Guys,
I picked up my R34 yesterday. I'm so happy, so I had to post up some pics :happy: They are a bit covered in rain, but this is the only gap I got :P
... and I had to take some pics of the pair :)
edit: and some interior pics just for Karl :) Sorry about the bad quality of these. Just ran out and grabbed them :)
Man that looks great.
If only I can afford a R34.
This means that I have to hate you until I can afford to get one. :bunny:
nice looking car mate, how much did it cost all up if you dont mind?
:P
Thanks :bunny: paid $25k for it. Pretty good price, so I was happy
was looking at this one and the red one they got for sale..but red aint my colour..so waitin for there new stock :happy:
Yep, thats the one :) I actually took another one for a test drive there too. Don't know if you saw the white one with the buddy club rims. Looked really good, but had a bit of minor accident damage. Oh, and I agree about red. Doesn't really suit the R34 I reckon.
This means that I have to hate you until I can afford to get one. :)
Thanks :) Don't worry, I can take the hate :) lol My friends are saying the same thing, and yet they all want me to take them for a drive :)
