Make: 1996 Nissan
Model: Skyline GTS-T M Spec Series 2
Milage: 99,000kms
Transmission: Manual
Colour: Silver exterior, black interior
Complied? yes
Currently registered? yes, expires 25 May 2008
Price: $14,900 negotiable. All reasonable offers welcomed. Regrettable sale as wanting to move overseas for next few years to live and work.
Contact: Michael on 0406 422 721 or email on [email protected]
Comments / Modifications: My car was imported from Japan in 2003, compliance plate dated May 2003. I bought it in August 2005 from the guy that imported it in Sydney. It is regularly cleaned, polished and kept to look its best. Oil and filter changed every 5,000km. I'm no street racer. Not driven hard. Well looked after pride and joy.
It has all the standard accessories - air cond, power windows/steering, 4 wheel steer, turbo etc. The list of after market modifications made to my car are:
- Mongoose alarm - Tinted windows - HKS blow-off valve - Turbo timer - Pod air filter - Front strut brace - 18 inch mags - 235x40x18 Front and 265x35x18 Back - Lowered with King Springs - Bendix Ultimate Brake Pads - 3inch HKS N1 exhaust system to turbo back - DVD player, amps, tweaders and subwoofer - Hybrid front mount intercooler - Upgraded front bar - Boost gauge
Images: My add from another website if this helps.
http://www.carsales.com.au/used-cars/priva...amp;Make=NISSAN
Edited by mickwa
I see this car at the gym and it looks nice :)
Thanks mate for the feedback. If you know anyone looking for a well kept Skyline please let them know of mine. :D
there seems to be a million of these cars for sale nowadays compared to when i bought it. surely though someone is interested?
if you want a car that has not been completely modified from head to toe this is the one. if anyone wants more info pls ask away, cheers :(
:P I WILL ALSO SWAP FOR A CHEAP CAR (eg. an old "roadworthy" CHARADE OR EXCEL) VALUED UP TO $1,500 AND THEN CASH FOR THE BALANCE. I STILL NEED A CHEAP RIDE UNTIL I LEAVE THE COUNTRY. GOOD CHANCE FOR SOMEONE TO UPGRADE AND GET RID OF THEIR OLD CAR AT THE SAME TIME.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
