Item:Nokia N73 Mobile Phone
Age:18 month
Condition:Good
Price:$300 ono
Contact:Pm best
Comments:Im selling my Nokia N73 mobile phone, I havent used it and i just thought is pointless sitting in my room.
Its locked to Vodafone and i know u can get it unlocked but dont know how much that costs.
It still has the box and cds and everything.
Will send anywhere in Australia at BUYER expensive.
Pick up is avaliable in the Hills area.
Thanks
https://www.sau.com.au/forums/topic/216979-n73-nokia-phone/
hey if you look on the internet you'll find a code to unlock from vodafone to optus, telstra etc. really easy ive done it to many phones hope this helps with your sale gl.
Yeah Thanks champ
I appreiciate it
https://www.sau.com.au/forums/topic/216979-n73-nokia-phone/#findComment-3921654
  • 1 month later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
