Item: GFB Stealth-FX adjustable BOV, atmo or plumb-back, or a mix, with adjustable spring pressure too
Age: Near new
Condition: Excellent condition
Price: $200 firm
To Fit: (What car) R33 or Stagea RB25DET
Contact: PM please
Comments: Excellent condition, sounds really good, doesnt stall when in full plumb back mode
http://www.gofastbits.com/index.php?parent...tion=stealth_fx
Item: Deatschwerks Nissan RB25DET injectors, highflowed to 550cc
Age: Brand New
Condition: Brand New un-opened condition, all rings and seals in package
Price: $480 firm
To Fit: (What car) R33 or Stagea RB25DET non-neo
Contact: PM please
Comments: Was going to use a Power-fc and these injectors, but sold the P-fc so no need for these either. Get a bargain on brand new 550cc injectors. Deatschwerks are the best in the business
http://www.deatschwerks.com/catalog/technical_info.php
Nissan sidefeed red 550cc
Latency Info.
5.88 6v
3.50 7v
2.62 8v
2.07 9v
1.80 10v
1.56 11v
1.42 12v
1.32 13v
1.19 14v
1.11 15v
1.07 16v
0.95 17v
https://www.sau.com.au/forums/topic/217194-rb25det-gfb-stealth-fx-bov/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
