Hi, been a problem for a while now, and its given me the s**ts. So i just want it fixed.
Took my chances buying a second hand upper control arm, was good for about a week then started squeaking, so i pull the bolt out of the bush and puts some grease on it,,,didn't help. It seems the bush moves in the metal ring, prob cuz of how much weight is actually on it.
Just wondering if i go genuine, which was about 400 before it is even shipped from japan, and not inc gst. Or can i get aftermarket items. Because genuine will only do the same prob again after a while...Do i do front and back or just front? If someone could give me some info in this area it would be very much appreciated, as I'm looking at selling my vl before October, and that is my transportation atm.
Thanks,
Julian
https://www.sau.com.au/forums/topic/217448-control-arm/
are we talking front or rear here?
just get some new poly bushes. 1/4 of the price of a whole new arm and locally available. Any suspension joint with a 10T press can get the old ones out and fit the new ones in less than an hour if they are half switched on
https://www.sau.com.au/forums/topic/217448-control-arm/#findComment-3839280
try a couple of the polyurethane bush manufacturers web sites
noltec
nolathane
whiteline
fulcrum (i think they have the superpro catalogue)
I think they all have on line catalogues
I had a quick check of the superpro catalogue as i have downloaded it previously when i was looking for bushes. They list an outer but not an inner. One of the other manufacturers probably list it.
just found a noltec catalogue, they list a full front upper control arm replacement set but don't specify whether it's gtr or gtst specific (i don't know if there's a difference). It's worth giving them a ring.
https://www.sau.com.au/forums/topic/217448-control-arm/#findComment-3840326
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
