33 M-spec Front Bar Cover
where you got them for $150? I only managed to find original type-m front bar + side skirts at $650, very expensive. bought it already so can't whinge anymore, and if no unexpected circumstances happens, I will get it mounted & painted end of this month!
  • 4 weeks later...
