HI GUYS,
I am having problems with my hicas light.
The light turns on about half an hour of driving and the back
wheel kicks out.
If i turn the car off then on again the light goes out.
The car is a 1993 R32 Gts4t.
Has anyone ever had this problem before i have taken the
car to several mechanics and no one has been able to
fix the problem.
Any suggestions will be greatly appreciated.......
https://www.sau.com.au/forums/topic/21788-hicas/
Hey Enrico,
We have found the problem when you put your steering wheel on make sure it is perfectly straight and the hicas sensor is in the right place.
what happens is when you have been driving for over 20 minutes the computer senses that you cannot be turning all that time and has a dummy spit the arse end kicks out and light comes on.
I had been to many mechanics here in sydney and none of them
knew what they were doing some supposed import specialists.....
Try this and let me know how you go.
Regards,
Daniel
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-477187
I am not sure about where the dead centre is i have tried to get the wheels as straight as i can and re fit the wheel.
No luck its still a bit off centre i will try moving the wheel i notch
again tomorrow.
If that doesn't work i am going to Unique Auto Sports on saturday for a service i might get them to have a look into it and
see if there is something i am overlooking......
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-482053
OK
There was something i overlooked.
ON the rod where the wheel fits onto has got a mark on it and geuss what i am 99% sure that this is the top dead centre mark.
Also on the standard wheel there is a mark on the top centre....
How stupid of me to overlook that i must have been drunk.
Hopefully this fixes my problem and more importantly helps someone else.
With the aftermarket wheels make sure you have a hicas boss kit with any luck they will have a mark top centre aswell and so they should at around $250AU ea.
I haven't seen one as of yet i am on a pretty tight budget and would rather do some performance mods than anything else.
Well thats enough crapping on from me i will be updating again tommorrow night with how it goes need to go on a freeway to test it out properly...
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-484017
Well i re-positioned my steering wheel today, and the light hasnt come on since so lets hope its all goot now!. However a funny thing hapened when i was driving home. I turned on my hi beams, and for a split second the Hicas light turned on, then turned off. Wierd. the globe hasnt blown thou.... Anyone have any ideas??
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-487577
Well im pissed off still not workin dont know what to do now.
I had the car serviced today and have been told that the front end bushes are F**KED and they will need replaceing.
Dont know if this could be contributing to the problem.
Might have to take it back to UAS and get them to have a look at it for me.
Dan
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-488216
I have a '93 GTS-4 and I am also having a problem (I think) with my HICAS, my light stays off while I am driving and all that, the fluid levels are all full but the back end seems to be kicking about now and then, especially when I go over high gaps in tarmac (like at the start of different surfaces with dodgy roadwork and bridges).
Does anyone know what might be the problem?
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-488505
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
