with regards to exhaust emissions when we get defected for this are they just looking for noise? or full gas emissions also.... so 90db or under is fine now ive got a 3" split dump/front pipe an xforce cat and a trust power extreme 2 catback exhaust, which an officer once said to me is "too big" (but not too loud) is there a restriction on size also? If i had a couple of resonators for example put in and got it under the 90db limmit, would this now automatically be a legal modification or would i need epa approval as well? followed by an engineeers certificate...or no certificate? can the police defect me for an exhaust without measuring the db? Also is there some sort of paper or certificate that you can get which states ur exhaust db level bla bla bla so u can show the copper that it does not contribute to noise etc and hence he can get out his on meter and test the db level.
ive done a search on these but there seems to be no definate answers for many of these questions, please do advise me on how to go about quietening the current system without loosing power but keeping it legal
https://www.sau.com.au/forums/topic/218054-adr-and-epa-exhaust-regulations/
2cents...
Theres no restriction on size, just noise. If they see fit though (when defecting you) they can order an emissions test i believe.
The popo can still defect you on anything thats Ok'd in your eng cert. As such, a different piece of paper saying your dB is xyz becomes moot. ... also they aren't stupid, they know people change zahust setups after being done, so they take pictures of your setup. Yes they can defect without measuring it.
Thats my rough understanding, unless somethings changed.
Btw my old PE2 was around 97dB at the required RPM, and then popped a 107 on rev decel. Thats a rb26 with stock front pipes, so yours could be closer to 100dB i would think.
Edited by GeeTR
my PE2 i thought wasnt that loud, but then I put the front pipes and hi-flo cat on.... now shes loud... i think I have an easy 100db exhaust.... that being said, its still quite quiet unless I bring the boat on boost
Very true GeeTR they make the rules as they go.
To answer some of your questions;
You can obtain a stationary noise test from any good exhaust shop. Costs around $60
As far as emissions go, the police can order you to emissions test your car at the rta inspection station at Botany or Penrith within 7 days. This does no happen that much and im not sure what happens if you live outside the city. This is free of charge.
As far as pipe size goes, if it passes emissions and stationary sound test and the pipe is above the minimum ride height there really isnt grounds for a defect.
:D
:D
your basic idea is right, however the details are wroung
1.there is no size limit "however if u have a 5inch exhaust im guessing ur legal ride height is compromissed"
2.you can have your exhaust tested at a exhaust shop, however it wont do shit for you when the police cheak it
3.the police cannot send you to the botany or penrith testing station's, they can however notify the d.e.c.c "e.p.a" which inturn will send off a nice lil letter, requesting you pay them a visit and "cheak" if you have all legel/certified modification's. also note an engineer's for the exhaust,fmic mean's jackshit because the testing station cannot certfy that is the exact same exhaust,cooler etc etc.. therefore if its not standard chance's are you will asked to rectify these problem's or head down and have it pass an emission's test..
so in short, there is nothing you can carry around with you to certify that your car is legal, from a noise side or emission's. engineer's etc only help's if the coppa doesn't do his job.
hey dude i gota PE II trust 2 with 3inch front dump pipe and high flow cat, i got a EPA and i had to get mine retested, so i put on my OEM catback with the high flow and 3inch front pipe, my dB came out to 87.9. So yeh. just leting u know .
im going to try and see what i can do just to quieten it down, i think liverpool exhaust can put 2 resonators in there for me without a problem...it might just scrape it...i think i read somewhere a resonator will cut down 5db...(i think) anyhow...how about a varex cannon? surely this will save a few headaches with the popo and a quick db test....
I live in singleton NSW and the cops here are really bad on defects. I had my car defected for Exhaust, front mount, and pod. The exhaust i got a test at the local exhaust shop where they gave me a piece of paper with the test results on it to keep in my glove box. The front mount and pod i was told i had to take a day off work, travel about 3 hours to penrith to have an emissions test to clear the defect. I put the standard filter and cooler back on to clear the defect until i got done again.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
