The most mature thing ive seen on this post so far hahaha
You sure i dont need to make another topic, i think i will aye lol Kellie is prob thinking what the hell is going on with my cruise topic its turned in a sex topic maybe more?
I DONT REALLY CARE I HALF STARTED IT
also if its that easy then why am i still single? ill tell you
*I am not a size 6/8 by any means
*I only get guys interested in me because of my car but when he finds out,
*he will not be driving my car any time soon
*I have a 6yr old
Bang they are gone
my son has a father, im quite fine with the way i look size 12 is healthy, i think i have a personality, i like going out to do things ect im kind, but i could go on but wont
so its not that easy!!
  • Replies 473
lol random thought,
imagine if someone miss read this whole topic and thought we were having a cruise with a speed date and look who's hot and a yeh i dont want to go on hahahahahahahaha
*I have a 6yr old
Bang they are gone
That sucks really! That means they want all the good things outta you, but none of the responsibility! Let em run Kell, they don't deserve you. :banana:
My GF has a 9yo boy and I don't see that as excess baggage or anything bad at all. I get along great with him and his father for that matter. If you want the girl, you gotta take the complete package ... family and all.
BUt you come across as a gal that takes NO shit ... and you shouldn't have to. :P
thanx ruby thats very nice of you to say x
No worries.
When you get to my age you realise there are three types in this world: those who have expectations of a partner (the selfish ones); those who have expectations from their partners; and those you have the same expectations for each other.
Hold out for the one who you share the same expectations with. That will only bring alot of communication, respect and honesty. A relationship, a real relationship, is a two way street. :P
im not scary cause im a :P
alright but i only know of one bunny thats not scary lol
and they are called playboy bunnies lol
my friend has a bunny and his sister is the only one that can touch it. it goes psycho at everyone else
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
