Make: Nissan
Model:1997 R33 S2 GTS-T
Milage:just past 100k
Transmission:manual
Colour:White (QM1)
Complied?Yes
RWC supplied?No
Currently registered?12 Mths rego
Price:$15000
Contact:Adam 0416 598 050
Comments / Modifications:I'm the second owner after it was imported. I've owned it for two and half yrs, when i bought it it had 3inch exhuast from turbo back. Since i've had it i've put a new high flow cat conv, fuel pump, FMIC, PFC, splitfire coils and heavy duty clutch and redline gear oil. I put sydney kids susp package in aswell. Wheels are 33 GTR with federal 595 SS tyres, backs are 245/45/17 and are brand new, fronts are 235/45/17 and have about 70% left. It has factory sunroof and ABS. The rear wing i don't know what it is but looks like a wide GTR item. Factory side skirts, rear pods and front lower lip. Drivers seat has small rip/wear in usual spot.
Car is set on 12psi high and 7-8psi low. At 10psi it made 180rwkw at SAU dyno day, it was tuned by Adam at JEM where when running 12psi it made 196rwkw, and if anyone knows Adam this tune is very safe and actually it has made over 200rwkw . I absolutely love this car and don't really want to sell it, but the wife says sell it. It is serviced every 5000kms.
https://www.sau.com.au/forums/topic/220653-1997-s2-gts-t/
You are selling it because your wife said "Sell it"? :D
Good luck with the sale mate.
That and with her getting a company car, we don't need two cars and i'm also looking at a company car soon and if i get it i'll be going down the GTR route.
Thanks mate, the way the market is i need all the luck i can get.
https://www.sau.com.au/forums/topic/220653-1997-s2-gts-t/#findComment-3891308
  • 1 month later...
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
