Brand New 25mm Arc Rear Swaybar S14/s15 But Should Fit Skylines Etc Too As Gtr Bars Fit Gts-t/s Series
5th November if you want to come out for a spin wakfield
By StreetWeapon · Posted
Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
