Item:BLITZ NUR Spec V Cat-back exhaust system
Age:unknown
Condition:Good, no leaks or serious damage
Price:$750
To Fit: (What car)R32 GTR, R32 GTST
Contact:PM or 0403596801
Comments:
As explained above I have a BLITZ cat-back exhaust system for sale! Its been removed from my R32 GTR, as I've upgraded to a twin pipe system. It came with my car when it was imported over. For the last year it was pretty much sitting in the garage as I didnt drive the car that much, and for about the last 2 months since it was removed it has been gathering dust. Its in good condition, pumps out a nice deep idle on the RB26 and an even meaner note all throughout the rev range.
I'll try to get pics up by tomorrow evening.
Please PM any interests or call/sms on the number listed above!
Thanks
Pictures up!
Its pretty dirty.i cleaned a small part with my hand, with a good clean all over it will come up nice.
Price dropped to $700.. open to offers as well
  • 1 month later...
Bump BUMP!
A reputable Japanese exhaust system, guaranteed fitment. Also power increase over a stock catback system, and most likely other cheapo brands
I can even install this for u 15-20 minutes max!
How much easier do u want it??!!!!
$450
will it bolt onto a 32 gtst. if u get it clean i'll make an offer. i live in adelaide how much to get it here. if u live close to grace removals i work here and they would sent it to me.
I could probably have it organised to go to your removal company, would definately save u a bit on postage. PM me your offer and we'll take it from there.. I'll have it cleaned up by the weekend.
Will fit HCR32
yeah they bolt onto R32 GTST's, to compliance my R32 GTR i used a standard catback exhaust system off an R32 GTST and it bolted up fine onto my GTR, and also my cousin used the same standard exhaust to comply his R32 GTST.. No difference in where the hangers sat.
Got any photos when on your car mate? Might be interested in making an offer if i can see it on, and depending on size.
I've already got a 3.5" catback exhaust, just getting over the oval styling and wouldn't mind the cannon look. Is yours 3" from the cat and 4.5" tip?
Cheers
Steve.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
