Hi people, I've Got some stuff in Japan waiting for new owners. Still got some stuff here in Sydney that's available for pickup as well.
* S15 rear brake setup. Everything u need for a 5-stud conversion plus more. Calipers, Rotors, Baffle plates, Cables, Hoses, uprights, hubs. Stripped from a mint s15 with very little kms. Fantastic condition, mammoth amount of meat on original pads, just a lil surface rust on the rotors. Very good for those looking for rear 5 stud conversion whithout the drama of converting to drum handbrake. A few people interested in sending interstate (still getting quote on delivery). Would MUCH rather a pickup as these guys are HEAVY. Chasing $350ono
* S13 SR20DET front and rear brake setup. Good upgrade for CA's. Original factory pads with 30%-40% meat left. Came off my 1994 180sx sr20det blacktop. Perfect working order. Again, would MUCH prefer pickup as these items too are HEAVY. Chasing $200ono
* S14a tail light set. Great condition. These are currently in Japan, can have it get to you by 3-5 business days. Chasing $350ono for the set.
* 2 X RB20DET Manual Transmission ECU's. These are currently in Japan, can have it get to you by 3-5 business days. Chasing $150ono each
* RB20DET AFM with Blitz SUS pod filter. This AFM is good for up to 220rwkw, POD is in mint condish, I run a blitz POD myself. Works amazing, for those chasing intake whistle (spool-up) this will do the trick! These are currently in Japan, can have it get to you by 3-5 business days. Chasing $150ono for the set, POD by itself in it's condition should be going at this price.
* R34 GTT stock smic in used but great condition. As you know, an awesome upgrade for the r33's and Stagea's. Will fit R32's with slight modification. 25% larger capacity than the stock r33 item. This is currently in Japan, can have it get to you by 3-5 business days. Chasing $350ono
* R33 GTS-T sii factory headlights. This is currently in Japan, can have it get to you by 3-5 business days. Will post a price soon. Don't hesitate to throw an offer for now.
PM me or call me on 0424 437 054. Located in Sydney's inner-west
Thanks guys,
Phillips
Edited by ph11ps
https://www.sau.com.au/forums/topic/221858-phillipses-market-of-wares/
Guest
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
