Hey guys
In the next week im installing a FMIC on my S1.5 skyline and wanted to cut the middle out of the front bar has anyone out there done this before and if so how did you go about it, i was thinking a bit of a DIY job would be fine althou im not too sure how it will turn out can someone please post some pics if they have done this
Cheers in advance Ben
https://www.sau.com.au/forums/topic/221950-r33-front-bar/
Hey guys
hey man. i found using a grinder with an old grinding disc works great. heres what i did with my 32.
https://www.sau.com.au/forums/topic/221950-r33-front-bar/#findComment-3912219
I have a s2 front bar, I used a angle grinder to cut out the center bar peices - was like a hot knife through butter!
As soon as i cut them out, the whole thing warped like it had lost the peices that keep it rigid. Once i stuck it on the car it was fine though... :thumbsup:
gl
https://www.sau.com.au/forums/topic/221950-r33-front-bar/#findComment-3913837
Hey guys thanks for the replys
I was thinking of using a Jigsaw to cut around the middle. Not really too sure how it will turn out thats all. I will post pics when completed *fingers crossed* that it doesnt look to Bodged
https://www.sau.com.au/forums/topic/221950-r33-front-bar/#findComment-3914834
  • 4 weeks later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
