  • Replies 125
Posted Images
at least wen u failed damo u did it in a 34.
wen that guy with the 32 failed it was in a 32 with 3 other ppl (idiot)
anyone got a pic of kellie's car with the marks of where she hit a pole?? <---- MAJOR FAILURE lol
https://www.sau.com.au/forums/topic/222709-fail/page/5/#findComment-3959010
YOUR in MAJOR TROUBLE :ermm:
https://www.sau.com.au/forums/topic/222709-fail/page/5/#findComment-3961949
IS THAT RIGHT
wlell a major FAIL would be NATHAN being BANNED from CRUISES until further notice
https://www.sau.com.au/forums/topic/222709-fail/page/5/#findComment-3964533
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
