I don't know what you mean by "the actual box of the seat belt..." ....
Perhaps posts some pics... if it's pulled all the way out, check for knots or anything that's preventing it from retracting... otherwise, the retracting mechanism inside the perhaps is stuffed?
Never done it myself, but if all of the above fails - open up the box where possible to see what's going on.
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3934115
yes its pulled all the way out , and it isnt retracting, yeah thats what i mean the mechanism inside could be stuffed and i was wondering how i could get into that to check it out.
how do i get into that part do i have to remove the seats or what?
thanks for the help
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3938779
im guessing your talking about the fron 2 seatbelts. if so i think the mekanism is inside the pillar, so take off the pillar and it should be bolted up in there, as for the back ones the same applies, cant remember if you need to remove the back seat. removing the pillars is easy, they just hold on by clips. be gentle you cant really go wrong.
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3954872
If you have an R33, two bolts at the bottom then the bottom section of the seat slides out, you need to pull it a little bit up when you pull it out.
2 more bolts on the top section, this has to be lifted up for it to come out.
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3960839
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
