Hi Peeps,
This months meet up has been changed slightly as stated in the old thread.. Speedracer isnt showing at the drive in's yet
So instead of missing this months meet..lets just go out to dinner and have a social evening instead :)
Date : 27th June (Friday Night)
Time: 7:30pm
Destination: The Outback Steak House
2A Hollylea Road
Leumeah
http://www.outbacksteakhouse.com.au/home.htm
Important: Peeps, please let me know asap so I can book a table!
Whos in?? :):)
Thanks Jess
https://www.sau.com.au/forums/topic/223652-southerncampbelltown-meet-up-thread/
  • Replies 74
yo.
im interested.
do they have vege dishes?
Yeah they kind of do...salad and pasta dishs and might have a buger..click the link and suss out the menu I am sure they will do something for you!
Do you eat fish or chicken Shane?? I have just known some Vegetarians that do :)
ah k sweet.
thanks Jess....im full vegie....except for mcdonalds hahaha.
meet at bunnings again?
if i cant make 730 ill meet you guys there...bloody trains never run on time!
Hmmm not driving to bunnings to drive all the way back to c'town.
I say meet at the place, cause its close to my house.
Jay this is the friday before the 2nd MRA round which I put you down to be my bit bitch for the day.
ah k sweet.
haha exception for maccas :)
Guys we will meet at the restuarant its very close to leumeah station and just behind Hungry Jacks and Red rooster!
Can we get a few of the old peeps out to this dinner...
Will book the table this week:
Sinful
Risking
Jazzy_i
Shane666
cracksta
jeffworld2
Jay this is the friday before the 2nd MRA round which I put you down to be my pit bitch for the day.
Yeah I know, looks like I'm crashing at your house again.
so we just having dinner? im getting busier i need to know what we are up to
plus can we go to wakie again soon>
Blacktown Drive in are only showing times for Tuesday and Wednesday :) I will ring to see if speedracer and the other movie will still be showing friday night.
Drive in's start at 7:30pm and it's a double feature.....I am still up for the drive in...
I am also up for Wakie maybe go to an open day in July for our meet up????
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
