I HAVE RECENTLY GOT A RB26 R33 GTST. 5 MIN AFTER PICKING IT UP IT SPUN BIG END BEARING. MOTOR HAS BEEN STRIPED DOWN AND THERE IS METAL EVERYWHERE. I HAVE TAX INVOICES FOR 2 REBUILDS PRIOR TO THIS ONE IN THE LAST 2.5 YEARS BOTH CAUSED BY SPUN BOTTOM END. THE CAR HAD ARIAS FORGED PISTONS BILLET RODS ACL RACE TYPE BEARINGS ARP HEAD STUDS, PMC SUMP BAFFLE N1 OIL AND WATER PUMP R32 N1 TURBOS RUNNING AT 15PSI REMAPS ECU STANDARD INJECTORS AND CAMS. JUST WANTED TO KNOW IF THERE IS ANYTHING TO LOOK OUT FOR TO PREVENT THIS HAPPENING AGAIN OR A COMMON PROBLEM LOTS OF MONEY HAS BEEN SPENT AND SAME PROBLEM SEEMS TO HAPPEN. ANY HELP WOULD BE MUCH APPRECIATED
Edited by adam Foster
https://www.sau.com.au/forums/topic/226101-my-rb26-not-healthy/
I would say get another engine builder.
my VG30DETT RACE motor, which pumps out 366RWKW, has been running for over 2 years now, over 20 race meets, some 400 race laps, where every gear change is at 7000rpm. so someone is ballsing up big time with your motor.
EACH TIME IT HAS BEEN A DIFFERENT PLACE LETS HOPE THIS TIME ITS DONE RIGHT
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
