Originally posted by Dark Sky 33
Dont be dissin my n/a...its cool. :D
im selling to buy a doped up silvia. 380hp garret turbo. big front mount. the works...wanna drag then...wouldnt call that much of a poo barger will ya :(
Kind of like driving around with a cardboard cutout. :D (jokes)
No the silvia isn't a 'poo barge' .
Originally posted by Munich
Theres one whiteone in Vicpark. Sticker says 12999 if memory serves. Been there quite sometime so try and do a good deal!
Where 'bouts in Vic Park? Is this the one u meant ----->http://www.autotrader.com.au/photodisplay.asp or is it a different one?
Thanx man.
Yep thats the one, at Centre Point Motor, at the lights rite. 1994 White R33 GTS25 for $14,274. Here try this link --> http://www.autotrader.com.au/photodisplay.asp or this one --> http://www.tradingpost.com.au/hotlists/pho...&hotlistid=W039
Cheers
Yeah tis why Im running NA at the moment. Thought Id save my dollars for something later in life, maybe even a GTR who knows
There is a fair bit for sale through dealers out there, bought in a last minute rush to comply before the rules changed I guess. NA apparently isnt available to import anymore?
have you got any specifics you want, mods you want, auto/manual, year?
Originally posted by Phat^Beatz
Anyone selling their skyline? Let me know. I'm actually in the market looking to buy a skyline, preferably with low kms and just an N/A not the turbo ones.
ight laterz...:burnout:
Hey phatbeatz, i have a 1996 series 2 N/A Skyline, 59000km, for sale, im on the verge of buying a house soon and need the cash fast, hence my car is a genuine bargain at the moment!
Contact me via PM or email me at [email protected]
:D
I am pretty sure thats the one and they had the car on the platform like the BMW 5 series on your picture.
When they had it there, it had one of those huge banners running across the window saying $12999.
Skydragon looks like he has a good car there, maybe check it out ?
Munich
