Make/Model: Nissan Skyline Series 3 GXE sedan
Year: 1989
Kilometers: approx 360000, odo stopped six months ago on 350XXX
Transmission type: Auto
Engine: RB30e
Colour: Champagne on slate grey
Modifications: Lowered with king springs, pacemaker extractors fitted
Accident History: Has damage to front l/h qtr from a carpark incident, few bumps typical of age
Asking Price: $800 ono
Contact Details: Email [email protected] or message me here
Other Comments:
Car is starting to show its age
Paint is faded on roof and boot
Diff is worn and makes noise, a bit clunky
Engine starts and runs fine
Auto trans runs fine
Interior is in very good condition for age/km's, slight wear on drivers seat
Front slotted brakes are a bit warped
New handbrake cables in rear
Needs new stereo
Has towbar fitted
Windscreen is cracked top center, needs replacing
Air con no longer works, hasn't for a few years
Temp gauge doesn't work, have speco 2" mech guage fitted
Car has some rust around front windscreen (not visible, but needs to be fixed to fit new windscreen), also some typical rust in front gutters (behind qtr panels)
Car has 15" bbs rims , 4 x 6.5" (original gts-r alloys, front + 2 spares, 2 x 7" on rear atm) will need new tyres on front soon.
Would suit someone looking for a project/track car or a cheap daily/parts, need to sell as I have a new daily ready to rego
https://www.sau.com.au/forums/topic/226408-fs-nsw-1989-nissan-skyline-s3/
hey would you put it on a truck and send it too wollongong???
very interested
That shouldn't be a problem if you organise. Payment for the car will be required upfront though. Also I'd prefer the buyer to have a look at the car so they know exactly what they are getting but thats your call.
Dave
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
