Item:
Tomei direct replacement fuel pump (255 l/ph) $ 400 (1 year old)
Apexi power fc (without h/c) $1100 (1.5years old)
Garrett gt 3040 turbo with vg30 rear .68 housing, in stock comp cover, built by ATS, $1700 (8 weeks old)
Blitz fmic, uses stock cooler pipes!! $850 ( 1.5 yrs old)
600cc creatd motorsport injectors $520 (1 year old)
splitfire coilpacks $440 (2.5 weeks old)
z32 air flow meter with plug $270 ( age unknown)
BSA 264 rims with 265 wide rubber rear and 235 front, 80-90% tread $1200 ****showed in pic****
HKS actuator $90 ( 1 year old)
HDI ebc boost controller $70 ( 7 weeks old)
Blitz atmo BOV $130 ( unknown age)
I am in need of a stock r33 turbo in order to get rid of the turbo and stock wheels in order to sell the wheels.
All parts are in excellent condition. basically as new. no ridiculous offers please. genuine buyers only
car is a r33 gtst series 2.
NO pics are posted as i prefer people to come and see the parts they want to buy.
Parts will be available in the next 10 days.
I am located in the wetsern suburbs, melbourne
drop a pm or call me if your chasing any of these performance enhancing parts
call between 9am and 10pm anytime
Anthony 0433447630
*make an offer :sick: *
I am selling all my parts because i want a standard car again.
(pic of car for wheels for sale)
Edited by R33GOD
  • Replies 89
Posted Images
price drop on a few items
power fc ecu : $1000 firm
blitz lm fmic : $750 firm
600cc injectors : $450 firm or will swap for stock 33 injectors plus $200 my way
z32 afm with plug : $220 firm
splitfire coilpacks : $400 firm
tomei intank fuel pump : $320 firm
HDI boost controller with missile switch : $50!
blitz atmo bov with adapter for stock cross over pipe : $100!!
bump bump bump!!! :whistling:
Edited by R33GOD
what kind of power was the turbo making on your setup and what is its power rating
its 500hp rated. immaculate condition
my motor was struggling to keep up with this turbo. lol
i made 257rwk on 11.7/1 a/f on 16 psi.
and 630nm torque on a bog stock motor.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
