Make:Nissan Skyline
Model:1995 R33 GTS-T MSpec
Milage:140,000
Transmission:Manual
Colour:White
Complied? YES
RWC supplied? NEGOTIABLE
Currently registered? YES
Price:$12,000 NEGOTIABLE
Contact:Mobile 0422 301 332
Comments / Modifications:No engine mods, Heavy Duty Clutch, Cat Back Exhaust
Images:Attached. Photos are of when i bought it but will put more photos up if requested.
Car currently is been driven once a week and is under cover during the week. Perfect stock car can either be a daily or be modded up. comes with a set of springs to be lowered and Apexi turbo timer havent installed cause have had no time.
Comes with original Skyline Matts. Car also come with Aus standard alarm with shock sensor and in cabin sensors central locking and Dark tinted windows. Which are not in the photos.
Please call if there are any questions.
https://www.sau.com.au/forums/topic/227485-r33-1995-mspec-gts-t/
Janaya - Yes the car is still for sale
OZ Car imports - Well i was told it the 1.5 same front as a one serie but the spoiler from the second series. No service history my uncle who is a machanic has done all the work on my car.
Jas-25t - Yep its a 1.5 series MSpec.
I got the guys on here to run the egine number through the nissan system and it came back as a 1.5 MSpec.
Just to let you know car will be going in for a service as soon as i find time to book it in. At the moment it need Spark plugs last time irdium ones where used. Oil i have only used Penrite oil, fule filter and airfilter last time i used Apexi panel filter.
Just remembered Gear box oil was changed last year as well as diff oil and the bearing in the gearbox.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
