  • Replies 177
Funny thing is I like it how everyone says every man and his dog has a R33 But I hate to say it R32's are f@rken everywhere now. So I wouldnt say that any more.
but yer throw RB25 in, I think thats what the R32's needed all along, GTR proves that :wave:
Maybe in your area, but around my place i only see R33's.....I suppose it depends on where you are located.
I was thinking of getting a R33 when I had my R32 as well... Then 2 weeks later a chick smashed into the side of it and it was a wright off... :)
So once i got the cash back I ended up getting a R33. Thought I might as well do the upgrade. The R32 was great for going sideways and doing burnouts, but the R33 does feel alot more comfortable to drive and the dash doesnt rattle, lol.
I think if your using it as a daily driver the R33 would be nicer to drive and it has the RB25DET! Which feels and sounds very Nice! :/ but the R32 was alot more fun!! Depends what your looking for :wave:
I keep saying it.. but know one listens... if I could get it working with AWD id have it in my GTR :wave:
lol coz 1 it wont work with awd
and 2 it cost waaaaaaaay to much
and i think the ls1 is a better engine?
hmm something to think about i geuss, iv seen good drag times with those motors, saw a 9 sec pass once
wont be a 9 sec car without spending 100k son
11s or 12s is prolly more realistic if you can get the power down
ps you will need to take into consideration supporting mods when doing a hi-po rb30 rebuild
eg, injectors 700-800
clutch 1k
ecu 2k
diff 1.5k
rb25 gearbox as your 20 will just do a round the world with the 30s torque 1.5k
and the initial engine rebuild 8k~ varies alot pending parts
clutch 1k
ecu 2k
diff 1.5k
All that stuff is the same for any hipo build, it's not exclusive to RB30s. The point was, if "building" an engine, look at building a 30.
You can built a budget 30 and come in well under 2k if you wanted to. If you have higher aspirations (like I did), then you should be looking at all those other things too.
My 30 cost just over 2k to build (I did get a good deal on a block/forged piston/head setup), so it's not just a stocker build. As soon as I built it I had to go spend about another 3k on injectors, z32 afm and a tune.
Already had a good clutch, 25 box was already on the cards (that was a 2.5k excercise what with custom tailshafts etc). Oh and then there's the 1.6k for a GT35R, $500 for a TiAl gate, then we get onto exhaust manifold and exhaust fabrication I have to do. Intake manifold that has to be made. Just picked up a full 32R cooler piping setup which should make things easier.
BASICALLY, you need a goal to work towards. My goal is 400rwhp (with lots of lowdown drivability) with headroom for more and I believe my setup will do it easily.
If you just want a bit more *poke*, then a cheap standard 30 build is leagues ahead of 20. A similar "cheap" setup would be to drop a standard 25 and box in there and leave it at that.
If you want lots of power then you gotta be prepared to spend the coin where it's needed!
Edited by bubba
i was thinkn just a 25, larger turbo, new ecu, cams, clutch, injectors, fuel pump, inlet manifold and a tune would keep my happy for a bit
That's pushing 10k right there.
thats 10k in parts not even labour yet
sell 32 get an 33 and save yourself 4k?
inlet manifold would also require custom pipe work more $$ there
nothing wrong with the stock one unless your going berserk
how much hp can stock injectors on a rb25 flow?
The y31 Cima had an VH41DE AWD option :)
But yes it would cost to much, for now...
2 guys I know of are attempting it, one in NZ, one in Sydney
mmmmmmm would be awesome even without awd :huh:
definately a good idea for a unique car me thinkz
You've spent more than 10k to get where? a mildly modded RB20? you need a goal and to plan how to spend the next 10k wisely!
I have a loooooooooooooong term plan to eventually put a VH41 in the 32 when I get bored with the 30, there was a guy over east selling a VH41 with crossmember and mounts to suit 32.. I tried to buy the Xmember and mounts off him but no sale :blink:
Oh, why inlet manifold? the stock will flow enough for about 365rwkw. I wouldn't change it unless you're in my boat where you need bonnet and pipework clearance with a large high mount.
And I think stock 25t injectors flow enough for a little over 300rwhp..
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
