  • Replies 177
Nah I don't wanna drive yours to see the handling, just the 30DET (and do a burnout, jump out the door and leg it)
You don't know where I live right?
Paul, $1200
How bout I take you for a ride.. I mean.. drive :D
*shrug* stock for stock a 33 is a better prospect than a 32 but for minimal mods I believe a 32 is better (upgrade parts off later skylines to be used). For massive mods then it comes down to personal preference, I know I'd prefer to waste heaps of money on a 32gtst, but that's just me :starwars:
Unless its a GTR
32 loses in every department
This aint a war its a slaughter!
Lucky I have a 32R then... and im sure Bubba's 25/30 will pwn all.
We haz teh power & teh good looks, the 33 is the ugly fat girl with a nice personality.
No 33 vs. 32 war, its a slaughter :(
Indeed it shall! Went for a ride in an interesting car last night Tristran.. you would like :(
Can't spill too many details coz it's secret squirrel shit, but if you're up for a random spontaneous cruise this weekend, let me know :P
People who heavily modify there car like bubba i give respect
but were talkin 33 vs 32 without any drastic changes (eg engine conversions)
so yes 33 > 32 no debate! and.... 32 isnt hawt either, old interior, ghey ass bonnet bend (unless GTR) not to mention piss weak
Yeah! I gotz rezpekt y0! :P
I find the 32gtst to be a good starter as far as getting into modding cars go. Lots of cheap upgrades off the newer skylines such as 25 turbo, 33 brakes etc. Then you get into motors out of the newer skylines, I opted for a different route and built something that doesn't come standard in any car :D
Indeed it shall! Went for a ride in an interesting car last night Tristran.. you would like :laugh:
Can't spill too many details coz it's secret squirrel shit, but if you're up for a random spontaneous cruise this weekend, let me know :D
so mikes got the 32 going? ;)
I've had the R33 and R32 varients of the gtst and I think there's very little in it appart from taste in car looks. Both of my cars could run low 13's with the stock turbo.
have to admit, my mate has GTS4 RB20 stock with fmic + basics, had NO balls, he's just finished RB25 conversion i havent been in it as yet, but he says its BIG improvement. he's having partay tonight will have to snap a pic/drive before too many beers.
has the look of the R32 + RB25.. ftw
Ive also had both r33 and R32 GTST varients
exterior can come down to personal choice but interior the 33 is light years ahead
bolt on some mods and the rb20 will be left behind
the 33 gearbox will also handle much more abuse then a r32 gearbox
another thing is stock vs stock
r32 runs 10psi r33 runs 7psi?
R32 GTST 9-12k
R33 GTST 10-14k
R34 GT-T 23-25k
34 more torquey engine compared to the 33
stronger gearbox again
larger rear turbo housing then the 33 turbo (same as a 33 turbo compressor side but with a vg30 rear housing stamped as OP6)
slightly more top end power
R34 is awesome but for money you cant go past a 33 bang for buck
so mikes got the 32 going? :O
lol yeah, when I posted that it hadn't been tuned. Went for a ride on Sunday after it was tuned and man.. that thing is fkn FAST! (just ask Tristran.. he was trying to keep up and failed miserably :sick:)
You should come for a blat sometime, need to see how it goes against a real car :ban:
Edited by bubba
:O Its true... awesome car, poor Matty got left back on the horizon, at least i stayed in closeish lol
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
