In order for the TV to work in australia you need a AV input but from what i know is in JAP they don't use AV stuff for the car.... its all wire and they are more then 15 wire for you to choose from .... again it will never work
its not a player buddy...its a screen...a dash cluster.
im not intending to watch tv on it.
there are some Ecu's the can plug into it and display info...
so i thought that would be kewl...
do a search on Epson management and i think ud come up with something
  • 8 months later...
i don't think u will able to get one for 700.
the last time i seen it in jap auction, they sold for 90000yen.
even u are lucky and got 1 for 70000, then add 5% yahoo, shipping, tax and profle of jap connect...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
