Hey,
This is so stupid that i had to post it. Someone stole the grill off my series 2 on Sunday night while it was parked in my carport. I was there and heard stuff but didn't realize what was happening until i saw it on Monday morning.
I mean for f9cks sake who does this shit? who goes around looking for cars that they can take parts off? like they can't afford to spend 150 bucks?? WTF? wasn't even carbon or anything and my car is stock as a rock.
so anyway this was in churchlands if anyone wants more detail (or has details) please pm me.
i am suspicious of a dark wrx that i had not seen before which was parked in the visitors bays that night. and i heard them come and go around the time i heard strange noises outside..
just a heads up for you all who don't have your cars garaged
https://www.sau.com.au/forums/topic/231901-stolen-grill/
i park my hr31 in the city. as i was leaving the carpark i realised my indicators were playing up. i though a bulb had just blown, i got home to find a front indicator (rectangle one in the bumper) was missing completely, not just the lens the whole lot including wires & plug! :)
r31jspec from r31 forums had a spare he gave me for free :(
https://www.sau.com.au/forums/topic/231901-stolen-grill/#findComment-4071480
well..got another grill - $100
turns out that they did break one of the stays on the light fitting that it clips in to. probably couldn't be arsed un-clipping it and just yanked the shit off. it was a new light as well.
wasn't pissed off at first but now it's really hit me how lame this is and the trouble i have to go to fix it. what losers if i ever catch the fu4kers i'll rip their eyes out
https://www.sau.com.au/forums/topic/231901-stolen-grill/#findComment-4073161
i park my hr31 in the city. as i was leaving the carpark i realised my indicators were playing up. i though a bulb had just blown, i got home to find a front indicator (rectangle one in the bumper) was missing completely, not just the lens the whole lot including wires & plug! :domokun:
r31jspec from r31 forums had a spare he gave me for free :domokun:
Same shit happened to my 32, except they didnt take the wiring just the indicator. Got orange ones for 50bucks but still a pain in my ass.
https://www.sau.com.au/forums/topic/231901-stolen-grill/#findComment-4075127
  • 1 month later...
This sort of stuff happens more than you might think - my Aunt has a lx ss hatch she has owned it since new. While it was in a parking garage in the city where she works she had her side mirrors stolen! Some people have no shame
https://www.sau.com.au/forums/topic/231901-stolen-grill/#findComment-4177898
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
