My R33 S2 is for sale as i am getting V35 shortly, it has always being my weekend drive and in very good condition (inspection a must). No modification only Exhaust and Pod Filter.
I am more than happy to take it to any inspection, given i don't have to drive more than 15-20 min max (Wynnum area or Morningside or CITY)
Milage: 104000
Transmission:5 Speed
Colour: Silver
RWC supplied? YES
Currently registered? YES
Price:13,500 o.n.o
Contact:0411272782 or [email protected]
Comments / Modifications:Cat back exhaust and Pod Filter
Interior - all power options as any R33 S2 and MP3 head unit and AMP/Sub.
i am a fuzzy owner so its being pampered , anyone who inspect the car will see that... serviced every 5K and 100K service done at 86K (when first got it)
email any inquiry and i will get back ASAP..
Dual Air bags was still an option on S2, but everyone optioned it so you think it came standard...
but unfortunatly...the Japanese friend who brough my car brandnew did not option it... :P
Thanks Guys for the comments
Just realized i have not mention about Wheels - 17inch Keiichi Tsuchiya designed wheels
also i put 255 / 30 / R17 Pirelli at the back (looks Phat !!!! from the back) and 235 /30 /R17 at the front
Still plenty left on tires...
Does anyone know how to edit the original post................
  • 3 weeks later...
  • 1 month later...
SOLD SOLD SOLD.. please delete tread.......
thank you for everyone who commented...
V35 here i come........ oh AUS $ please go up....plz..
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
