I am in the process of putting in a Boomerang car alarm and I want to set up the door switch (when someone opens the door it goes off) and the alarm has 1 door input and when I hook it up to the front door I then run a wire from the front door switch to the rear door switch then to the other side rear door then to the front door all in a series to the red (+) wire but only 2 doors are working (all door pins are ok)and it is saying on my dash when I open 1 door that they are all open even tho they are not...and only 2 doors will activate the alarm and the others wont..is this the correct way to wire it up? Please help me...
Also in the liberty (90) where is the Tacho wire as I need to find it for the remote motor start...i cant seem to find it under the dash...any of you guys installed xtra tacho and can tell me where the wire is please other wise I will need to go to the coil in the engine bay(id rather not).
Cheers
Homer
https://www.sau.com.au/forums/topic/23281-boomerang-help/
