Got a damaged 33 gtst-t rolling shell with long motor and manual gearbox for sale.
The engine has 193k on it, last compression test showed all cylinders were between 143 and 145psi. Gearbox is fine, doesn't crunch or slip out of gear, has a nismo short shifter in it.
The damage is only to the front of the car, needs a new bonnet, front bar, headlights, radiator, engine fan and I think that might be it. Rest of the car is in pretty good nick, if you would like pictures of the car just leave your email address and I'll send them asap.
Any questions just PM me.
Cheers
Make:Nissan
Model:R33 gtst-t
Milage:193,xxx
Transmission:Manual
Colour:Silver
Complied?Yes
RWC supplied?
Currently registered?No
Price:$3000
Contact:
Comments / Modifications:Front end damage
Images:
Yeah I've got some pics, what's your email and I'll send them across.
Damage isn't that bad, will definitely need a new front bar, bonnet, headlights, fmic, radiator and engine fan. Front guards are unharmed.
Don't think I'll be wrecking the car.
Would've liked to transfer the RB and all the running gear into an s13 but funds do not permit unfortunately.
Any other questions, just let me know.
do you have pics how bad damage is and are you going to consider wreckign the car?
Hey mate where bouts in NSW are you located? could i have some pics? [email protected]. thanks
Hey champ, the car is located in Goulburn, I'm heading back to work now, I'll send you some pics when I get home.
Cheers
hey mate really interested in your car.
Can you email me some pics.
[email protected]
And if you can could you ring my office (02) 66527 766 and ask for Tony
Cheers
Sent the pics, and I left a message for Tony on that number at 12:35 to call me back.
Thanks
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
