$50
still got it
Are you selling it with the surrond, not just the radiator, im after the plastic surrund part that sits on top where the top hose fitting gets connected down to the engine. Mine broke yesterday so if it your plastic part is in good nick ill take it the radiator and surrund for 50
  • 4 weeks later...
Dude, Still have the head? Or Did u sell it? Just curious to Know how much they are worth as I have a 2 of em back in my old house in the garage...
hi Im after the r33 front mudguards, do you still have them? if so how much? thanks
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
