Item: WRECKING WHITE 1994 R33 GTST
Condition: front driver side been smashed
Price: $3500
Contact: NAM 0421175987
Comments: i had a accident yesterday and i hit the bus :D , the engine in the car is still in good condition was replaced a month ago with a 1995 which done 110000km's with i think it was 150psi through all cylinders and the gearbox was from a 1997 series two that done 80000km's. Am not separating anything... i just want it all gone. has rims, original GTR spoiler adjustable, 300kmph speedo and the list goes on. more pics of the smash front later on tonight
heres the link of some pics of the car
http://www.carsales.com.au/used-cars/priva...amp;sort_type=2
Edited by nszs
https://www.sau.com.au/forums/topic/234374-wrecking-1994-white-r33-gtst/
OKAY, i found no buyers so im going to STRIP THE CAR DOWN NOW.
ENGINE 1995 110XXXXkm's 150psi through all cylinder, going to double check tomorrow - $1500
GEARBOX 1997 series 2 80XXXXkm's MANUAL GOOD CONDITION $ 1300
300 nismo speedo cluster 98xxxkm's on it - $200
3inch exhaust with 3.5inch cannon - $450 straight bolt on stock r33
GTR spoiler a small crack near the lights - $200
taillights - 150 for both
seats - 150 for both
Greddy Front mount intercooler - $450 straight bolt in, just need to cut reo bar from memory
and lots more just pm me!!!!!!
PICK UP, can post you organize it.
call me on 0421175987 or sms , as i currently dont have access of the internet at home now
Thank Nam
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
