Make:Nissan
Model:98 Skyline R34 GT25T
Milage:52000
Transmission:5sp Manual/Turbo
Colour:Black
Complied? Yes
RWC supplied?Yes
Currently registered?Yes
Price:$22500
Contact:0415261008 or (0402554373 after 5:00pm)
Comments / Modifications
Mean looking Gt-t definite head turner, Nice power, runs beautifully
Complete genuine Nismo body kit.
Car has always been garaged and well maintained with servicing every 5000kms with high end motul oils.
Modifications:
Exterior:
- Genuine Nismo S-Tune front bar
- Genuine Nismo S-Tune side skirts
- Genuine Nismo S-Tune rear bar
- 18 inch rims
- GTR working rear fog light
- JDM HID kit
Performance:
- Turbo back exhaust with blitz nur cannon
- HKS front mount intercooler
- Automatic turbo timer
- HKS oil cooler
- Ogura racing clutch (ORC)
- HKS hyper-d Coilover suspension
& Plenty more mods...
Call now don't miss this opportunity
price is negotiable will consider any suitable price. email me if you want more pictures
of the car. If i miss your phone call message me ill call you back.
Buyer will not be disappointed, regretful sale,no swaps, car must go
https://www.sau.com.au/forums/topic/234418-98-skyline-r34-gt-t-for-sale/
Make:Nissan
Milage:52000
Colour:Black
Complied? Yes
RWC supplied?Yes
Price:$22500
Contact:0415261008 or (0402554373 after 5:00pm) email:[email protected]
Car has always been garaged and well maintained.
Modifications:
Exterior:
- 18 inch rims
- JDM HID kit
Performance:
- HKS oil cooler
i forgot to ad that the car is fully registered and expires on the 10th of April 2009 and if anyone needs more info like the Vin no. or any other inquiries call, msg or send me a pm
question. is that dirt or surface rust around the coilovers and strut brace?
interested in this along with another black GTT in sydney. will you be willing to get the car compression tested (paid by me obviously)
hey budy yeah of course, i can get the car compressioned checked from my work or you can pay for it i dont mind and around the coilovers its dirt and very minor surface rust on the top bolt but thats it .Give me a call and we can organise a time for you to come and check the car out
i recently had it pass a full rego check and it cleared so it must be legal and theres plenty of skylines out there with aftermarket non airbag steering wheels going round
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
