Hey everyone,
Just wondering if i can bother you fine SAU's with a quick question. I recently just got a cheap 2nd hand PC foy my bedroom (the main pc is getting too full of my bros crap haha) mainly to do uni work, for the net and the odd movie maker clip
Anyway i cant get the usb ports to work correctly. I plug something in, i recognises it, then it just locks the pc up, no keyboard no mouse, nothing. I've tried 2 differnt thumb drives, and my external hdd and it all does the same thing. All this stuff works fine on my other pc, and checked driver version for the usb driver and its exactly the same as my other pc (so its not the driver). I've uninstalled it and reinstalled the driver just in case but no good.
Im not that good with pc's anymore, so i thought i would see if any of you had any idea what was causing the problem. I had a quick search on the net and it seems that its a pretty common problem and most recommend getting a usb hub that slots into a pci port, but dunno....
I quickly undid the case and it has the main usb ports directly on the motherboard (they are at the back of the case), and i have 2 usb ports for easy access at the front of the case, and there are wires that connect the front bit to the motherboard, but it all looks connected and fine.
Some people said that if the device draws too much current it can lock up the pc, but my external hdd doesnt use the usb power (it has a seperate 240v connection), so it can't that either.
So should i get a pci port usb hub or is there an reason for it locking up?
/essay :D
Thanks for any help
Steve
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/234485-quick-pc-question/
open up Computer Management and go to the Disk Management tab
Unplug all other USB connected devices including KB/M if they are USB
Plug in a USB key and see if computer management brings up another drive
If it does but still freezes your on your own, PCI slot USB controller is an option
http://www.ple.com.au/snapshot.php?inventory_id=9441
That one costs $18
Edited by Topaz
cheers for the reply
what do you mean by computer managment? i cant find anything along the lines of that in control panel.
I've been going into control panel-system-hardware-device manager
and it shows the following under the usb tab:
5x root hub
5x Via rev or later USV universial host controller
1x via USB enhanced host controller
all show up fine, no conflecting issues and the computer finds no faults
Also theres no usb ports being used (mouse and keyboard have there proper slots), i dont mind buy a pci usb slot but i kinda want to know why its doing it haha
Are you actually getting a Windows error or is it just freezing? Does the screen go black or blue?
Could it be as simple as having the most up to date drivers?
Just freezes, mouse doesnt move and no keyboard actions work (ie ctr alt dlt, alt f4 etc)
Doesnt go black or blue screen and no error messages.
I bought a pci card off ebay for $10delivered (comes with cd driver), so i'll see if that fixes it.
I originally thought it was the driver since it said it was a 2002 version, but my other computer runs the exact same driver without any problems. The pc thats having the problems isnt hooked to the net atm so its hard to get updates, but if there was another update i would of thought my main computer would be running it.
Edited by R34GTFOUR
right click My Computer
select Manage (you get Computer Management)
select Disk Management
Plug in a USB key
Also I notice you have a motherboard with a VIA chipset which could be the issue
Download the 1.10 filter patch from here and see what that does
http://www.usbman.com/Guides/VIA%20Tips%20and%20Tricks.htm
Edited by Topaz
i've heard of this happening
what you do is
you go out and buy an imac
and youll never have any problems ever.
bingo karl *hi5
Plug in a USB key
that could also be the problem - if its an old computer (like say 04/05) VIA were having lotsa updates in regards to the usb drivers
Plug in a USB key
haha didnt even know that computer management was there.... :banana:
cheers for the link, will try that tonight
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
