Hi,
Ive been doing a bit of research on diff upgrades for my r32 gtst, and there are a few things that im having difficulty finding out.
The first option is to go for an R32 gtr diff and replace the drive shafts and hubs to suit. Apparently though, the gtr drive shafts are 40mm longer than the gtst ones (SSS told me this), and im not sure if it will cause problems. Is there anyone out there who has done this conversion, and is it a simple procedure? Im getting varying views when i use the search button. The gtr diff is a 2 way, but i dont want an obnoxious diff, as the car is 95% street driven. All the hardware will cost about $1000 plus extra if i have the gtr diff tightened, so im not sure if its better to just go one of the options below:
Nismo GT LSD Pro TT Model in 1.5 way. $1119 + delivery from Greenline. Didnt really want to spend this much, but i suppose the gtr diff will end up costing similar in the end. Also, ive heard good things about this diff in street driven applications. I'd rather spend extra for something i can live with (almost) every day
Cusco Type RS in 1.5 way. Its $857 + delivery so its a bit cheaper, but i have no idea how it performs. Anyone have any experience?
I'd probably rather buy new than second hand, as the gtr diff will be old, but i was wondering if my standard driveshafts will be up to the task if i get the Nismo or Cusco (the gtr shafts are thicker).
Any advice or suggestions would be appreciated.
Shaun.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
