Does anyone know if the snow button does damage to the car if you have it on for a fair while??
I know it takes off in second, would this be a problem after a while??
Before you all scoff, if you are just cruising around, try it for a while and you can get used to it.
The fuel economy improves heaps and the car pulls a lot lower revs, and when you need to go you can just flick the switch!
https://www.sau.com.au/forums/topic/234611-snow-button/
my understanding of engine load is that it is greatest at low rpm in high gears
this means consistent taking off in second gear will put a huge amount of stress/load on the transmission / engine leading to premature drivetrain wear
its up to you but when you think about it, if it was the best and easiest way to do things then it wouldn't be a special button, it would just be the way it was made in the first place. and this is not the case.
https://www.sau.com.au/forums/topic/234611-snow-button/#findComment-4110640
The thing is, the primary function of that switch is to take off with less tractive effort in low grip conditions. The button's existence isn't about "the easiest and best way to do things" all the time, its about the easiest and best way to do things in a specific situation.
Even if high load at low RPM caused no extra stress on the drivetrain/powertrain, the button would still be there as you don't always want to take off in second gear with a less sensitive electronic throttle.
It'd be like if someone asked if turning up the stereo to a certain point would damage the speakers, and then replying that if the speakers were meant to go that loud then there wouldn't be a volume knob then the stereo would just be made to play that loud in the first place.
I'd agree that it probably does more harm than good, though. Taking off in second does load up the driveline and cause extra wear, and that is a bad thing. The few bucks you save in fuel won't offset the cost of reconditioning your engine because you've made it lug for a lot of its shortened life. Its not like the V35 is a tow vehicle, and first gear is just there to provide more tractive effort while pulling a trailer.
https://www.sau.com.au/forums/topic/234611-snow-button/#findComment-4112297
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
