didnt get it engineered , problem solved though as i bought a varex muffler electronic silencer kit , when i get pulled over press of a button car goes quiet , so car can be as loud as you want but press of a button makes it so quiet , good for neighbours and stuff..
hey just wondering...
with the varex...did u pass at decc campelltown?
i went there with my varex and he wouldn't let me pass
https://www.sau.com.au/forums/topic/234872-adr-83/page/2/#findComment-4142149
Na wouldnt work with the varex i put a standard exshaust back on when i passed my noise test , then just put the varex back on , The DECC Is very by the books , good thing is once you have passed keep the paperwork they give you with you at all times so theyeve got you on record , mabye hellp you out in the future ..
https://www.sau.com.au/forums/topic/234872-adr-83/page/2/#findComment-4142327
ahh i see
yeh i was gonna go back to them with a stock exhaust on and then come back and put back my varex
i would recommend the varex if u haven't already been defected...i think i got a few cops off my tail b4 when i pressed the button
but he didn't pick up it was a varex
i closed it and unplugged it and everything
went there and did test
and he did sound test
he said i passed
but it seems so unlikely that such a big tip only blows 86
then when he hoisted it up
he looked inside and said therse sumthin blocking it
i told him its permanent
and he said its not that easy, because sum1 can just unscrew it and its off kinda thing
but yeh
campelltown guys good guy
he told me i can take out my intercooler and i wont have to go epa
rather than saying...i have to go epa b4 giving me a chance
https://www.sau.com.au/forums/topic/234872-adr-83/page/2/#findComment-4143987
what year model is your car? cause im pretty sure the legal limit is actually 91db
guys my defect was cleared 3 months ago
what im saying is it got ticked to go to an AUVIS (i.e. blue slip) but i didnt go to the campbelltown place or the place in granville i went to a place in moorebank, and thats what my question was about when do you have to go to granville or campbelltown (when you get an epa defect?) not from the coppers?
but anyway the legal limmit is 90db but they permitt up to 95db (so that exhaust shops dont go broke etc)
https://www.sau.com.au/forums/topic/234872-adr-83/page/2/#findComment-4144139
that's stupid hmm so you just get a letter to go to the DECC but I don't understand why I didn't get this letter?? Does everyone or just a select few - or does it have to do with if the copper that smacks u a defect if he notifies the EPA ?
https://www.sau.com.au/forums/topic/234872-adr-83/page/2/#findComment-4144738
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
