Hey all,
Have browsed the forum without success and wondered if anyone can point me in the direction of a pattern to make handbrake/gearshift sleeves? ( R33 )
I could to just cut up the current black ones and use them for a template, but I would prefer to keep them in case I ever want to sell the car since the new ones are gonna be hot pink LOL
Thanks in advance :3some:
  • 3 weeks later...
Hey all,
Thanks in advance :)
Hot pink boots sounds awsome, Think I might do that myself, anyway, I dont know how successful you will be getting a pattern, best bet is to unpick your old boots and use for a template. If you ever want to sell the car you can get replacement black boots from $20 on ebay, or you could make another pair in black, or just stitch the old ones back together once you make a pattern off them. :ninja:
Edited by Tritty
