Hey guys :(
Just looking for some eyelids for my R34, ive had a little look around and couln't find to much only a few sets of ebay. Just wondering if any-1 could point in the right direction or even a sponsor that might sell them ? and what is need to install just a tube of sikaflex ( how ever it's spelts :D )
https://www.sau.com.au/forums/topic/236298-r34-eyelids/
i made my own custom eyelids out of pinstriping tape
i have a white 33 and taped them up so they look like s14 style
not bad for 8 bux, and the color matchs up pretty well with most paintjobs
plus u can make em look however u want
always gettin other lines pullin up askin where i got mine from
giv it a go, u can always peel it off
https://www.sau.com.au/forums/topic/236298-r34-eyelids/#findComment-4139072
i got my uras ones off ebay, from status tuning i think.
they the same as nomura ken uses but i recon u need a
more agressive front bumper not the nicest with a stocky
i would be looking at getting a full bomex kit hopefully with in a month or so aswell that wont be a problem :)
can any-1 recomend a good place to buy kits of, found a few but with very poor customer satafaction :)
https://www.sau.com.au/forums/topic/236298-r34-eyelids/#findComment-4139160
i would be looking at getting a full bomex kit hopefully with in a month or so aswell that wont be a problem :(
can any-1 recomend a good place to buy kits of, found a few but with very poor customer satafaction ;)
I got a Bomex Kit and C-West Eyelids ready for my 34...havn't fitted them yet because im waiting for my wide ass rear panels and front gaurds.
I got my eyelids from Carmate though like a couple of people have already mentioned, they come unpainted and probs need a decent sanding before you fit them and paint them.
Goin a lil off track (sorry), I thought the bomex kit would be awesome but if you havn't already bought it you might want to reconsider to another kit, they are quite over the top 'ricerish'....if i had an option i might actually have gone with Impul or something a bit more suttle. Anyhow its up to you i guess, just telling you from my own exp. I'd say the URAS eyelids would suite the Bomex kit better than the C-West ones. (Also Carmate is in NSW and has a site you can purchase and get the parts you need shipped to Tassy). Everything can be done online and they are quite reliable form own experiences buying stuff from them.
https://www.sau.com.au/forums/topic/236298-r34-eyelids/#findComment-4142275
cheers mate that was a great help ;) havn't bought anything as yet still on the *prowl* :(
https://www.sau.com.au/forums/topic/236298-r34-eyelids/#findComment-4142321
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
