Item: Avs model 5 rims 17 x 8 (38) front and (30) rear, 60% nexon tread
Age: unknown
Condition: 3 almost perfect, 1 slight gutter rash
Price: 1400 O.N.O
To Fit: (What car) 32, 33, 34
Contact: Scott 0430 362 050 or P.M
Comments:
These rims are in almost perfect condition except for rear right which has slight gutter rash. Both front and back have around %60 tread on nexon 17/235/45.
Please P.M for pics
Edited by InH3aven32
https://www.sau.com.au/forums/topic/236350-17-x-8-avs-model-5-rims/
$1100 O.N.O
Come on boys these are some nice jap rims
There a bargain at this price
LOL dude i noe the pain..i got the same set that are 18X8 that im trying to sell and noe one wants them. GL with the sale mate coz ppl this is a BARGAN!!!!
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
