  • 4 weeks later...
hmm thanks for posting about this I had the same question.So just take to a shop that can calibrate it.Well I have seen look alike cluster's on the net though.I might go with one of those instead.Maybe the nizmo cluster and change it to white with bright azz leds ^^
