Hi all... if you are looking to put together a group buy we have this service available at MYC. We will negotiate a price on ANY of our products.
So if you are interested in organising a group buy of ANY of the products on modyourcar.com then please contact us at http://www.modyourcar.com.au/customer_serv...20Buy%20Service
https://www.sau.com.au/forums/topic/23750-if-you-want-to-organise-a-group-buy/
I have the R32 (turbo and non turbo) available for $280 online (RRP $295). Of course group price of 10 would be cheaper.
We can organise R33 ones but we need to get someone to send over their gauge cluster to my "dial maker" so we can manufacture more dials.
If someone doesn't mind doing that then we can organise a group buy of 10 no worries!
Let me know! And you can trust that this is completely SAFE and you WILL get the gauge cluster back!
On the other hand I will just check with my supplier anyway to see if an R33 version has since been made.
I have the R33 GTS-T and GTS Luminous dials... I will make them available on the web site tonight.
If someone wants to organise a group buy for dials then get in contact with, otherwise you can simply buy them off the MYC web site.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
