ive been looking through heaps of dyno sheets ect and ive decided to change my turbo and go
for the 3071r
im chasing 260rwkw out of my r32 rb20
at the moment i have like a gt30 on it but it hits boost real late at like 5000 - 5500 rpm
ive been told a 3071r will do it and come on boost between 4000 - and 5500
just dont know what housing's to use and what all the specs are that i need for it to run well on my car
Any help i can get from you turbo experts would be much appreciated
even if i could find out the exact cartrige number so i can just order it would be a bonus
cheers
https://www.sau.com.au/forums/topic/238838-3071r-on-the-rb20/
thanks for the search i couldnt find any of that before
now the tdo6 comes into play how different do you think the tdo6 ls 8cm is compared to the 3071r?
im not sure if the tdo6 will bolt up too my setup and i dont wanna buy a whole kit for it?
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
