yeah whatever mate cause you're having so much luck selling them as it is now
i have had someone pm me an offer of $75 for trims anyway mate so if i do sell them you wont be getting them anyway.. i dont see what your problem is, your trying to buy something off me.. remember that, no need to be stupid about this, you made an offer and didnt get it .. carry on with life ..
keen on the seats, rear and front.
Any rips or burns on them?
Thanks,
Rhys
hey mate, no rips tears or burns .. one of the front seats has the rear pocket coming off on one side a little bit .. have the lot for $200 if your keen ?? thanks ash
all i got left now is t28bb turbo and jasma exhaust, gtr wing (black) and 2 doors left .. i will sell the turbo and exhaust for $800 if someone wants them both or i will drop price for individual items for cash .. gtr wing will take $75 and doors $75ea ..................
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
